jjj240 wrote:Opened up 1959 Greenie for inspection/repair.
As shown in attached, Drive Sleeve Assembly (Gilmer) used 205KDD (background).
However, it is hard to see the model for Quill (single bearing).
Could anyone confirm please?
5/8" x 35mm x 12mm <<<<<<<<< s/b 11mm
Drive sleeve = 25mm x 52mm x 15mm.
dusty wrote:It might be worthwhile to double check the part number for a single bearing quill to verify that it is not 5/8" x35mm x 11mm (205KDD).
Shopsmith part number 502962.
My BAD It s/b 11mm! mistyped!!!
bucksaw wrote: ↑Fri Mar 20, 2009 5:12 pm
Industry standard numbers (Can be cross referenced to most bearing manufacturer parts by your bearing supply house)
Quill - Single Bearing (Gilmar & Poly-V): 6202 ZZ 5/8"Quill - Double Bearing (Poly-V): 6002 ZZ and 6003 ZZ
Bucksaw, are you still active? Or could someone edit the original post in this thread? I made the mistake of not reading the entire thread and instead went by the numbers in the first post and fell into the 6202 vs. 6202-10 / 15mm I.D. vs. 5/8" I.D. trap. It would be nice if the original post included a warning about that and emphasized that the correct bearing is 6202-10. It's a long thread and google tends to take you to the beginning, so unless you take the time to read the whole thing you'll miss the nuance. Thanks!
Greenie SN 362819 (upgraded to 510), Bandsaw 106878, Jointer SS16466
First post sez ; [Quill - Single Bearing (Gilmar & Poly-V): 6202 ZZ 5/8"]
No not obvious but it IS there.
In this case, 5/8" x 35mm x11mm nails it!(ignoring other variables)
Different mfrs have different ways to assign part # and deviations.
Indeed. But generally one assumes that if number XYZ is stated as correct then that seems safe to believe. But in this case the correct number is XYZ-aa (where "aa" is a parameter that substantially changes the specifications of XYZ). So XYZ (by itself) isn't correct but the implication is that it is. So a heads-up wouldn't be inappropriate
