Pocket Holes without a jig?
bainin
Post by bainin »
I know I saw a thread using the table tilt and horizontal drilling to setup pocket holes.
But- how does this compare to getting something like a Kreg R3 jig?
The jig seems like it might be faster, but it is limited to 1 1/2 " board thicknesses whereas the SS should be more flexible but likely slower.
Anything else I should consider?
b
cham-ed
Re: Pocket Holes without a jig?
Post by cham-ed »
I'm not familiar with the K3 but my K4 handles 1/2" and up. I certainly prefer it to setting my table at 15 degrees and adjusting a Forstener bit to the right depth etc...
I use the Kreg system a lot and I like it. I prefer it mostly because I can either take to the job or use it on the bench.
I have both the K3 and the K4 but now that I own a K4 I hardly ever use the K3 because of the ease of clamping with the K4.
The K3 and the K4 both work with 1/2" to 1 1/2" thick materials.
However, controlling bit length is equally important when using the Kreg pocket hole systems.
bainin
Post by bainin »
The Kreg systems seem quite popular.
I have come across 2 others which seem to get good reviews.
Porter Cable 560-which if you follow the link-has been discontinued.
https://www.portercable.com/products/po ... system/560
And this Armor brand one -which seems similar to the PC
https://armor-tool.com/product/auto-jig ... le-system/
All of them are in the $100-$150 range.
The auto-adjust features of the Armor-Tool are very intriguing. I don't know if KREG has come up with anything like that but I won't be surprised when/if they do.
However, for now I'll stick with what I already have.
Thanks for posting the link, bainin
bainin
Post by bainin »
As usual, I do a bunch of digging and end up going in a different direction.
I ordered this one...which seems to have a lot of the features of those above at a lower price point with some added benefits.
https://masscaproducts.com/
1. Aluminum body rather than plastic
2. USA made-small family run business
3. standard hole sizes-so if the drill bit is crap, i can replace with a kreg bit
It does not have the auto-adjusting depth feature of the Armor unit, but has a built in step height knob for depth setting which looks easy to use.
b
