How do you save a board that you cut too short?
RFGuy
Post by RFGuy »
📶RF Guy
roy_okc
Re: How do you save a board that you cut too short?
Post by roy_okc »
Keep track of your planing progress.
https://www.youtube.com/watch?v=3-ZpAX_mygM
Roy
Laser engraver
garys
Post by garys »
Just use your board stretcher to take care of that problem. It is April 1 after all.
Also, you can use the pasta press concept. You roll your dough through rollers that make it thinner, wider, and longer. You can do the same thing using your 12" planer on wood. Just remove the blades and run the board though a few times until the pressure of the rollers makes it longer. It will be a bit thinner, but that's OK. :mad:
