Jig Saw Oil
Jig Saw Oil
Am I correct in assuming the proper amount of #10 oil in the crankcase is achieved by filling it up to the filler hole with the Jig Saw sitting in its normal upright operating position? TIA
Any one have manual for the Jig Saw (greenie version, not 10 e/r version). Or know where I can get one? SS does not list it.
mikelst
Post by mikelst »
I believe that is correct but... I have an older manual and will try to look it up tonight if no one else gets to it. My problem is the part numbers don't match from the older Magna (Greenie) manual to the newer Shopsmith (Grey) one. I need a part but have so far been unable to identify it to part number.
Mike......... Rowlett, Texas, near Dallas
86 MK V 500/520. 59 MK 5 Greenie Shorty. SS Jointer, SS Planer,
SS Bandsaw, SS Lathe duplicator, SS Belt Sander,SS Molder & Shaper,
SS Tenon master jig, SS Mortising kit, SS 2 1/4' Drum Sanders, Ringmaster, DC3300....
hobbydad
Post by hobbydad »
I am also interested in this question, as I would like to start using the jig saw that came with my SS.
I would like to add a question to this (in hopes that I won't be labelled a threadjacker). Since my jigsaw has probably sat for a long time, would it be beneficial (or even possible) to do some sort of "flush" of the oil in the crankcase?
I will also look at my manual, but I think it is from the late 80s/early 90s.
Thanks,
Loren
hobbydad wrote:I am also interested in this question, as I would like to start using the jig saw that came with my SS.
Thanks,
Loren
If it IS a Jig Saw rather than a Scroll Saw I do not think there IS much difference.
What makes you think it has ANY oil in it? They are notorious for it leaking out over time(or maybe the shop gremlins are drinking it!:p ). Probably wouldn't hurt! Will not be easy to empty. Resist the temptation to remove the cover. Those gaskets were wishful thinking when NEW!
mickyd
Post by mickyd »
JPG40504 wrote:If it IS a Jig Saw rather than a...........
Resist the temptation???:confused: Isn't that the reason they invented Permatex gasket maker?
Sunny San Diego
mickyd wrote:Resist the temptation???:confused: Isn't that the reason they invented Permatex gasket maker?
I DO hope it IS different(improved) from that shellac based stuff they(permatex) used to sell. That stuff is impossible to remove! IMHO some discriminate filing(smoothing out the mold variations) would improve the ability of any gasket material to seal the oil inside the crankcase. I think I prefer Bill Mayo's make a gasket out of gasket material better(opinion at this point, not tried).
hobbydad
Post by hobbydad »
JPG40504 wrote:Any one have manual for the Jig Saw (greenie version, not 10 e/r version). Or know where I can get one? SS does not list it.
Were you looking for something specific in the manual or looking to obtain a copy? The item number on my manual is 505644, but that returns no results from a search on shopsmith.com.
Loren
hobbydad wrote:Were you looking for something specific in the manual or looking to obtain a copy? The item number on my manual is 505644, but that returns no results from a search on shopsmith.com.
Loren
IMHO one NEEDS a manual for each item one possesses and must maintain.
johnmccrossen
Post by johnmccrossen »
Check out #877086. This is still a good item number for jig saw info. Don't know if this is helpful but good luck. John McCrossen
http://www.shopsmith.com/ownersite/faq/jigsaw.htm
John McCrossen
Everett, Wa.
1954 Mk 5 SN 269454, 1955 Mk 5 SN 316013, 1960 Mk 5 SN 360792, 1962 Mk 5 SN 380102, Magna band saw, (2) jointers, (1) belt sander, (1) air compressor, (1) jig saw, (1) strip sander, (1) 20" scroll saw, DC 3300 dust collector, Sawsmith RAS, Craftsman table saw, 13" DeWalt planer, Triton 3 1/4 HP plunge router & table
BigEd
Is this your saw?
Post by BigEd »
I took a quick look on the OWWM site under Magna. Is this your saw?
http://www.owwm.com/mfgindex/pubdetail.aspx?id=2703
