Removing sandpaper from disc sander
How do you remove the sand paper from the disc sander without damaging it and when it is damaged, how do you get it all off and cleaned?:rolleyes:
Sawmiller
Sawmiller
I never tried without getting it wet, because at the academy I attended, the guy told us he just soaked it in the tub at the hotel!! It didn't take much to do, I used " GUNK" to clean off the left over glue, dried it off, stuck the new paper on, sprayed on a little WD40, wiped it down and never thought any more about it. I did not get any rust.
- a1gutterman
Hi Sawmiller,
And WELCOME to the forum. If you visit this thread, I think that you will get your answer.
https://forum.shopsmith.com/viewtopic.php?t=2671&highlight=removing+sandpaper+disks
There are other threads too; you can use the search function, found at the top of the page in the red bar, to help you!
Tim
Try using heat to remove the sandpaper. It may be reusable, but don't count on it. Once it's off, clean the disk with mineral spirits.
- a1gutterman
You can not use the velcro system for sharpening, and that is a major use of the conical disk.dlbristol wrote:I just looked at the older thread, and realized that Replacing the paper was part of the issue. Didn't SS have a velcro system for both the flat and conical disk?
Tim
Yes, you are correct, the velcro system CAN NOT be used for sharpening. The heat buildup destroys the velcro - believe it, don't test it. If you have a velcro system you don't need, send it to me.a1gutterman wrote:You can not use the velcro system for sharpening, and that is a major use of the conical disk.
However, I use a flat disc for all my sharpening tasks and I use the conical disk almost exclusively for edge sanding.
I just purchased extra sanding discs. I have (3) standard discs. One is setup for sharpening, and the other two are setup with different grit paper, and I also have the velcro system. If you watch ebay closely, you can get them at a fairly reasonable price with shipping. It seems most items on ebay for SS go pretty high. But, patience is the key here, just watch and wait. I got my last one, including shipping for $33.59
Pat
Oregon
1992 SS 510, 11" Bandsaw on power station, 4" jointer, Pro Planer, Incra Miter 2000, Incra Ultimate Fence Router Pkg, Grizzly 6" Parallelogram Jointer.
Oregon
Like dragon, I now have several flat and conical disks so that I can access different grids.
That said, putting the disk in the oven on a low setting will soften the glue and make it easy to remove an old sanding disk. 3M77 can be used to re-fix old sanding paper on a disk. However, as Nick pointed out to those of us who attended the July week-end, do not use 3M90, as it is permanent.
Permanent, like really for ever and ever permanent or extremely difficult?:eek:8iowa wrote:Like dragon, I now have several flat and conical disks so that I can access different grids.
