The Ultimate Sawsmith Radial Arm Saw Thread
drumone
Re: The Ultimate Sawsmith Radial Arm Saw Thread
Post by drumone »
Sadly, I've never had those. Here's the listing on Marketplace: https://www.facebook.com/marketplace/it ... 4996955874
Somebody PLEASE go pick that up!
drumone
Post by drumone »
Consider it gone! All that's left is the column, arm, carriage for the motor, motor, and a few other random parts. When I get a chance, everything but the motor is going to recycling. And I'm only giving the motor another week or so to see if it sells on Ebay or Marketplace. I highly doubt it at this point.
edma194
Post by edma194 »
I am looking for the parts in the Base, Column, Arm and Table numbers 17,34,35, and 58. Plus anything else to replace the Shaft Riser, Shaft Stub, Coupling, and Bushing for the column riser crank. Please PM me if you have those available still.
apexsunguitars
Post by apexsunguitars »
On this day, one more Sawsmith 500003 has been saved! I still need to go through it thoroughly but it looks to be in good shape aside for most of the column lift assembly being missing. I guess its back to stalking eBay.
Good luck with the stalking.
StoneTableStudio
Post by StoneTableStudio »
I recently acquired a Craftsman radial arm saw, for the purpose of using its right-hand thread on the right side of the motor. I admit I haven't even looked at the reverse-thread of the primary spindle. But since someone posted a photo of the right-side spindle, with a drill chuck mounted on it, I thought someone might want to know it's size: 1/2-20.
Now, a question of my own:
I currently have a drill chuck mounted on that 12-20 spindle, but what I'm really after is a direct adapter straight from 1/2-20 to a standard 5/8-11 (standard angle grinder thread). (I currently have a jury-rigged set up: a chuck, clutching a drill-adapter with a 5/8-11 on the end, on which I screw a quad adapter flange, with a 7" flush-mounted diamond, stone-cutting blade. The motor is rotated 90% so the blade is horizontal. I will use it to "shave" stone slabs down to a uniform thickness, as part of my stone carving process.
I have found only a few places that offer a 1/2-20F to 5/8-11M adapter, but so far the parts are mislabeled 5/8-18, or the companies are going out of business and not responding. If anybody has a viable source, I'd be obliged.
edma194
Post by edma194 »
StoneTableStudio wrote: Thu Jan 02, 2025 10:38 am
Amazon Hole Saw Arbor
Won't cost much to find out if it works.
StoneTableStudio
edma194 wrote: Thu Jan 02, 2025 1:50 pm
The hole saws adapter you linked to, is correct on the female (1/2-20), but incorrect on the male (5/8-18 instead of 5/8-11). I did actually order one earlier, but then discovered the description was mislabeled. I've since seen the same part labeled correctly as well as mislabeled.
The part I want will probably look something like this (link deleted). Unfortunately this company seems to be going out of business and isn't responding to my queries. And hopefully the $93 price is a typo.
Reason: Remove link spam
tmomrik
Post by tmomrik »
Not trying to hijack the thread, but in my search for a 1960s Mark VII, I came across a package deal of the Shopsmith along with a Sawsmith radial arm saw, also had a few SPTs with it. As I was unloading everything at home, I got a bandsaw, jointer, belt sander, air compressor and spray gun, grinding and wire wheels. Everything except the belt sander are in the gold paint, then looking thru the manuals, I realized that the accessories were most likely a package for the Sawsmith. It seems that the only thing I am missing is the Add-a-tool bracket. Anyone know where I can find one?
