Maxi Clamps
notfoxworthy
- Silver Member
I,ve had them since they first came out early-mid 80's use'm from time to time. great for squareing stuff,also you can push things out as well as pull'm in.Kinda like a shopsmith configure them for what ever need arises,also used them a while back for an adjustable throat hot wire foam cutter(made a new hot tub cover saved myself 100's over a new one).Takes some time getting used to but they work fine for me,but some say I'm simple minded, had to much fun in the seventies I guess.Ya'll behave& make us proud see'ya bye.
swampgator
alisfair
Maxi clamps
I have two set. If I ever start fishing in the river again I will use them as sinkers. For me they are a hassle as I incorporate other means to clamp/separate wood products.
alisfair
Maxi clamps
- pieceseeker
I acquired 1 set along with the SS stuff I got several months ago.
Here's some of the setups in the maxi-clamp manual.
[ATTACH]22129[/ATTACH]
[ATTACH]22130[/ATTACH]
[ATTACH]22131[/ATTACH]
[ATTACH]22132[/ATTACH]
My personal favorite....
[ATTACH]22133[/ATTACH]
I think using these clamps take a little practice to master....even says so in the manual.
- maxiclamp 1.jpg (68.59 KiB) Viewed 1360 times
- maxiclamp 2.jpg (119.6 KiB) Viewed 1362 times
- maxiclamp 3.jpg (136.96 KiB) Viewed 1362 times
- maxiclamp 4.jpg (164.96 KiB) Viewed 1361 times
- maxiclamp 6.jpg (142.35 KiB) Viewed 1361 times
