Lathe chuck for turning a bowl
hobbyist7
Post by hobbyist7 »
Thank you all for the excellent ideas! I think I have a good game plan now and will be able to experiment economically while encouraging his interest.
Happy turning!
Chris
Culprit
Post by Culprit »
What did you decide on?
Culprit wrote:What did you decide on?
hobbyist7
Yes Please do tell!;)
Also do tell us how it worked out both building hardware wise and building kid's interest wise.:cool:
hobbyist7
Post by hobbyist7 »
Will do. I plan to get the larger face plate and follow the gluing process described above, which I think is similar to the approach I used about 30 years ago.
In your experience, how round does the outside of the bowl need to be before turning it? Unfortunately, I don't have a band saw, so was thinking I'd start with a square and just begin cutting off corners with a circular saw until the angles were more and more obtuse. Any guidance on the number of sides I should aim for (e.g., 8-sided would probably be too rough...16-sided?)
Chris
beeg
Post by beeg »
4 or 8 sides should do ya okay. How BIG is the blank?
beeg wrote:4 or 8 sides should do ya okay. How BIG is the blank?
Compared to a 12' long 11" diameter tree trunk weighing 350 #, it should be a 'snap'.
Unless a very large blank, octagonal is a good place to start IMHO). Exact cutting not required, just knock the corners off(make some corner wedges!):D.
