Jimjmoore65 wrote:> Maybe the blade needs cleaning.
It almost certainly needs cleaning now. It was pretty clean when I started. Maybe it was/is dull?
I swapped out blades - for my SS rip blade - worked fine. I also reduced speed to M/N.
I guess the 5/8 arbor could be at fault - but looks pretty hard to damage easily.
Anyhow, now I can finish cutting the MDF sheet into shelves for my Mom's cabinet.
Thanks for the help,
Jim
I think you answered the question, you said you had two blades a rip blade and an 80 tooth blade. You said the rip blade worked fine.
I think the problem was MDF and an 80 tooth blade. MDF generates huge amounts of dust (huge amounts.. cough... choke...) I think with the speed and the dust getting packed into the teeth and the friction was causing the MDF to burn almost instantly. Once you switched to the rip blade which had much more spacing for the (huge amounts of dust... cough... choke...) and lowered the speed your burning ceased.
I do hope your using a dust mask as MDF creates a huge amount of nasty and toxic dust.
Also is it near fatal to most saw blades so I would be looking in the phone book for sharpening service. I have a designated MDF blade that I use whenever I cut MDF. The blade was sentenced to cutting MDF when it made me mad because it cut some very important wood too short. Hey I had to blame something.
