Project question/dilema
Other method(s)....
>>>what other methods I might use to accomplish the task <<<<
1.
Put the stock in a tube (or pipe ) that holds it tightly. Clamp a block beside the blade to rest the stock + pipe against. Nibble the corners off the stock while turning the pipe to round the stock. Set the fence on the right side of the block and blade to be the depth (guage) stop. Lower the table until the diameter is 1/2" .
2.
Find and mark centers on the square stock. Make a stop w/ a nail sticking out of it, clamp the stop with the nail parallel the sanding disk. put the center of the stock on the nail point and sand the material off the stock by rotating the stock and moving the sanding disk against the stock.
Second method may yield a rounded shoulder.
I made round tenons on square stock w/method 1 on a table mounted router. Method 2 was used on irregular stock that needed a tenon. Good Luck, and if you can believe it, Work Safely.
1.
2.
MK V 520; MK V 510 w/PP DIY Upgrade; MK 5 500; Jointer; Bandsaw; Sliding Table; Conical Sanding Disk; Sharpening Guide, Lathe Duplicator, Jigsaw, Scrollsaw, Beltsander, Ring Master, Biscuit Joiner.
Router table and a round over bit?mrhart wrote:I started a project over the weekend. I'm working with a piece of walnut 3/4 x 3/4 and about a foot long. I need to turn the ends into 1/2" round about 2 full inches or so. When I'm done it would be a square rod thats round on the ends.
I don't have anything for turning but the SS standards, no fancy chucks ect.
Can someone tell me what other methods I might use to accomplish the task.
- terrydowning
You could also glue waste blocks onto the ends of your blank. They should hold for turning between centers. This has the added advantage of not marring up your ends with center holes and spur marks.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
With some tips from each of you and little more thought, I documented the fix. Here is a few pics.
[ATTACH]19027[/ATTACH]
[ATTACH]19028[/ATTACH]
[ATTACH]19029[/ATTACH]
[ATTACH]19030[/ATTACH]
[ATTACH]19031[/ATTACH]
- Oct 1 2012 219.jpg (161.17 KiB) Viewed 1978 times
- Oct 1 2012 220.jpg (92.18 KiB) Viewed 1978 times
- Oct 1 2012 222.jpg (142.24 KiB) Viewed 1980 times
- Oct 1 2012 223.jpg (94.26 KiB) Viewed 1983 times
- Oct 1 2012 221.jpg (81.33 KiB) Viewed 1979 times
R Hart
Hooray!!!!!!:)
- terrydowning
