Dust Collector Hose
wdelliott wrote:Dusty,
Thanks for idea on flex hose. I ordered mine from Woodcraft.
The fit is difficult. In fact, I can't get the flex hose to go over the lower guard. Did you have fit difficulties?
I'm open to suggestions for getting a successful fit.
You can see in the photo I posted at the beginning of this thread (Post #3) that I have mine on the lower saw guard.
It fits tight and I had to work it into place by sorta screwing it on but I would not say that it was difficult and it certainly fits. I bought a clamp thinking I would need one to hold it but I do not.
I am really pleased with this hose as an addition to the lower saw guard. It does not interfere with the table post like the elbow and hose did. I can slide the carriage back and forth with ease, even with the hose connected. It totally eliminates what has always been a minor frustration to me.
Oh! That reminds me! Meant to post these pix last week.
The Woodcraft hose 'on sale' is likely the cheaper one, not the one Dusty got.
I got one anyway.
[ATTACH]20219[/ATTACH]
[ATTACH]20220[/ATTACH]
sta flex hose.jpg (399.04 KiB) Viewed 1189 times
sta flex hose box.jpg (429.11 KiB) Viewed 1190 times
JPG40504 wrote:Oh! That reminds me! Meant to post these pix last week.
I got one anyway.
I have the hose only (without the end connectors) mounted on my lower saw guard. Is that maybe why they don't fit the same.
Yours is definitely a different hose.
dusty wrote:I have the hose only (without the end connectors) mounted on my lower saw guard. Is that maybe why they don't fit the same.
It came with the swivel connectors loose in de box(they are removable).
IIRC there was a $2 difference in 'normal' price.
wdelliott
Dust collection on drill press mode
Post by wdelliott »
Dusty,
You came up with a good solution with the use of the flex hose. I'm wondering if you have a dust collection strategy when in drill press mode. The flex hose seems like a good solution there, but the clamping to the table leaves me at a loss. The SS parts seem expensive for what you get.
555582 Dust Collection Utitlity Vacuum Extension ... $52.95
(Item may be on back-order or is made upon ordering)
555520 Extra Extension Support Bracket ... $4.55
556186 Stay-Put Dust Collection System (Includes Stay-Put Hose, (2) End
fittings, bracket and clamp) ... $42.59
So, I am wondering about a suggested clamping solution for the flex hose when drilling.
Thanks.
Wm. D. Elliott
Dallas, TX
1972 Model 500; upgraded to Model 7; bandsaw; belt sander; joiner; planer pro; power stand; OPR; Biscuit joiner; router tables
Thanks.
I don't think that it can be considered a solution and it certainly cannot be called good.
No. At the drill press, I just sweep it off onto the floor and pick it up later.
anmius
Post by anmius »
This is what I use for dust collection when in the Drill Press mode:
http://www.shopsmith.com/ownersite/cata ... chment.htm
Abraham Lincoln
