Note to Admin: ShopTip Videos
admin
Post by admin »
Thank you for your effort in locating these and putting the list together. Your help is much appreciated.
Thanks
Admin
Ron309753 wrote:Perhaps you can check with Nick or Drew? It's likely that Drew uploaded them.
In the meantime, here the Shoptip titles that had Google videos and the corresponding Youtube videos. Can you modify the webpages so that when someone clicks on the arrow to start the video it will open a new window with the Youtube video?
Ten-Cent Mortising Gauge http://www.youtube.com/watch?v=fv-V3zLUJmA
Belt Sander Fence http://www.youtube.com/watch?v=sbdM-bs8j-g
Preventing Router Bit Slips http://www.youtube.com/watch?v=rviSVhx5kqc
Avoiding "Back-routing" http://www.youtube.com/watch?v=yXXjpqxQrUw
Auxiliary Fence for Sliding Table http://www.youtube.com/watch?v=b3pCSG76JR8
Turning Precise Diameters http://www.youtube.com/watch?v=OGUyupl-Nnk
Sanding Plywood Banding hmm, couldn't find this one one Youtube:confused:
Zero Clearance Inserts Rats! can't find this one either.
Making Wooden Trivets http://www.youtube.com/watch?v=uygTzLpoStk
Abrasive Cleaning Stick Strike Three!
Using a Boring Bar for Lathe Turning http://www.youtube.com/watch?v=PKL7uMoUR_E
A Long Handle for the Footswitch Dammit, this is getting annoying!
Making Biscuit Joints in the Middle of a Board http://www.youtube.com/watch?v=ufknvWEYlf8
Using a Cone Cutter to Shear on the Lathe Duplicator http://www.youtube.com/watch?v=dXYlarLDasw (note: this is raw video)
Sharpening Knives on the Strip Sander Well, another MIA!
Double Bar Clamp Veneer Press http://www.youtube.com/watch?v=9Jh8N2JyNBE
Lower Saw Guard Maintenance http://www.youtube.com/watch?v=rtRWrAny52k
Aligning a Workpiece for Crosscutting http://www.youtube.com/watch?v=puDvyCfqWPQ
Making Square Corners with Corner Squares http://www.youtube.com/watch?v=XhfLXgyAO58
The Trick to Using Hand Screws Son-of-a...,this one is missing too!
No Slip Glue Tip http://www.youtube.com/watch?v=NLSTsk3Tx1Q
Sharpening Curved Scrapers Well, here's the link, but... http://www.youtube.com/watch?v=7McwpmFZ6Us (this is also covered in SawDust Session 16)
Removing Rust with Potatoes http://www.youtube.com/watch?v=qYgnHDB3VNI
Collecting Sawdust While Drilling http://www.youtube.com/watch?v=duOmbukSZ-A
Lift Assistance for the Table and Headstock No luck on this one!
Stacking Featherboards http://www.youtube.com/watch?v=xY0-79iG9Gw
Cleaning Up Epoxy and Silicone http://www.youtube.com/watch?v=H10al_ELFAY
Undercutting a Tenon http://www.youtube.com/watch?v=JVchU-tKF7M
Curing Planer Woes http://www.youtube.com/watch?v=GFqi_Y4xtUg
Wrapping a Board Around a Box Not to be found on Youtube.
Compound Miters with Sliding Table http://www.youtube.com/watch?v=qwHKtgM9-CM
Waxing Sliding Tables, Clamps, and Jigs http://www.youtube.com/watch?v=QXHK3536ld4
Band Saw Extension Tables http://www.youtube.com/watch?v=3y95p0wXwM4
Sincerely,
Ron309753
Shopsmith I.T.
beeg
Post by beeg »
dusty wrote: Then while continuing the browse with a fresh cup of hot coffee, I found these.
Dusty, did ya send that link to the Admin? So he can restore the link on shopsmith.com?
