I may have the Shopsmith DIY tool bug
billmayo
Post by billmayo »
There are so many ways to connect this type of external equipment to the Shopsmith. I always tried having a quick way to connect and disconnect whatever tool or equipment I modified/constructed to accept power from the headstock. The belt was a little too loose for me in the video plus the link belt runs smoother and is adjustable. I found if you place the V-belt pulleys at least 16" apart, you can function with a 90 deg twist in the belt path without problems. I would jig up my first try using wood to see if it looks and operates somewhat within my expectations. Then if it seems like something I would be using over time, I would use aluminum "L" shape & bar metal to build my next model. I use a lot of slotted holes so adjustments can be done. My drilling, tapping & milling Shopsmith would get quite a workout at times.
apexsunguitars
Post by apexsunguitars »
rpd wrote:Have you seen this YouTube video for a Shopsmith/StewMac Buffing Station?
There is also a thread covering the build on the Telecaster Guitar Forum .
Yes I did, he has some nice ideas for his build. I want the bottom area under the arbor to be clear of a pedestal so I think the drill press mount will be an improvement on the design plus allow for a height adjustment. He mentions in the build that he is trying to for a quick and cheap solution and so am I. However, I think I can save the money for the right angle gear drive by making my own arbor from 1" threaded rod and pillow block bearings. I do like the StewMac buffs that he uses there but their buffer arbor is now ridiculously priced. The Shop Fox arbor that I was thinking about using doesnt have a 1" shaft and is more narrow than the StewMac version.
Two each Shopsmith Model 500, 505, 510s. Sawsmith Model 500003. Most of the SPT goodies aside from the compressor and the Planer.
mgdesigns
Post by mgdesigns »
The guy who made that video is a regular poster on TDPRI, and has also made a great SS long belt sander with fret board radius attachment. He goes by name of Guitarnut. He makes some great mods for the ShopSmith, of which someday I will duplicate.
Hand Engraver of Metals; Maker of Exquisite Kindling; 1955 Greenie Mark V (NOW with a 1989 Headstock); Magna Band Saw; Magna 4" Jointer; Miscellaneous Craftsman & Porter-Cable electric woodworking tools.
3D CADCAM Designs - Gemstone Facetor
apexsunguitars
I have seen the belt sander too, i subscibe to his youtube account now. i prefer compound radii fretboards and i was cringing at dropping the cash on the grizzly version of the swing arm rig and his DIY version is pretty polished. The only thing that I might try is to figure out a way to swing the belt sander up 90 degress into the vertical plane so that i can attach a wrap around table for sandling bodies. I would just have to figure out a good pivot axis that would match up with the SS going from horizontal to vertical mode.
