Life is good found a wiring diagram for the mower. I was going to send it to the repair shop before I found the diagram.
Solenoid on the bottom of the carb is to shut off the main throttle valve to prevent muffler backfire on shutdown. B&S large OHV engines give off a shot sound on shut down. This supposedly stops it, if you shut down from normal run throttle. However if you have been idleing you will probably still get the backfire.
My flooded engine guess may be right. Seems a lot of guys report this. If after checking the float and making sure it is good and everything is clean and not sticking. Most guys just install a fuel shut off. Probably a good idea for any engine where the gas tank is higher than the carb.
One guy said his leaked about a half gallon into his oil sitting over winter.
Once I get this fixed I will change that oil cause I suspected there might be fuel in it.
I have new outlook on life since I found this wiring diagram. Seriously they have more wiring harnesses and wires in this thing. 3 fuses 3 safety switches and a "safety solenoid"
The one control wire to the starter soenoid is positive that must pass through the PTO safety, the neutral safety and the starter switch. The other wire is a ground which passes through the "safety solenoid".
The safety solenoid is only activated when the key is in start or run position and only if the positive is can flow through all the safety switches. If the solenoid isn't activated then it puts a dead short on the magneto and kills the engine.
Figure that out without a diagram. Oh yes and then you have the seat switch will drop the safety solenoid if you take pressure off the seat while the key is in run position.
You want to even guess how the lights work?
