504209 Long Key ... $1.35
(Item may be on back-order or is made upon ordering) - what I wanted and ordered
501320 Short Key ... $1.46
motor sheave keyway which way up? and more ?
Hi Dusty - just searched for the part number of the short key and I got your post
http://www.shopsmith.net/forums/showthr ... ght=501320
with the pic you posted in post 5 above so i think they have sent me the wrong key.
I also believe you got the idler shaft key.
The motor shaft key is standard key stock and is straight. I am not sure of the size(3/16"? 1/8"? 5/32?) since I be 'out of town'. The end does not need to enter the fan sheave spacer. The key must be inserted fully into the keyway in the fan sheave. The fan sheave set screw holds the key in place. It should not be long enough to reach the sloping end of the milled keyway slot, but stop just short of there.
When tightening the fan sheave set screw, do not be bashful. Blue loctite is my preferred 'insurance' against loosening.
Glad to hear they know as much as 'we'!:Dtunznath wrote:just heard back from shopsmith they said if it has a hook it is the wrong key
