heathicus wrote:I had considered a computer power supply. I actually have a couple stashed back just for the purpose of converting to a "lab" power supply. But, different amps are supplied with the different voltages and I felt that would invalidate the test. If differences were notable, then was it the voltage or the amperage that made the difference? So we thought it best to make sure one of the values stayed the same across the experiment. We had decided on voltage as the variable and amperage as a constant, but I'm still unsure about that decision. Time to change it is just about out, though.
I did present some of the other variables to him as possibilities for the experiment, such as those you mentioned, frank81, but this is what he wanted to test.
I'm going to ruminate on everything that's been said here.
Quick question, though. How do I tell which wire from the wall warts is positive and which is negative?
Doing that will prove that the voltage will not affect the result as long as the current is the same!!! i.e. There will be only incidental differences in the results of all three samples.
ALL the work is performed by the current. More current = more results etc.
The hardest thing to do when determining what to 'do' is to make sure only one parameter is varied. You already got the list of things(parameters) to control/vary between samples.
Put yer multimeter on a high dc voltage range. If analog touch the leads to the output terminals/wires BRIEFLY. Observe needle deflection. You can figure it out from there. If digital, it will indicate polarity or an error.
Only do that after determining the wall wart does not tell you on a label.
The +12v portion of a desktop computer supply should provide more than enough current.
If not. the +5 volt portion will.
All else being equal, either the voltage or the spacing will affect the current. By using a common power supply (voltage) only the spacing will affect the current. Even if the voltage varies during the test, all three samples will be equally affected and any current changes will share a common ratio to each other.
I do think as the rust is depleted, the current on each sample will vary, but that will also be a constant for each sample, just not at the same time interval.
