Photos of the mentioned modifications?
Much appreciated!
Some suggested uses for model 500 table and parts
cooch366
Sorry for the LONG delay
Here is my use of an old 500 table. I can use all of my fences on it.
Now if I can modify it so it fits on my new MK7, i'd be even happier...
Steve
Steve
- Shop_0004.JPG (54.37 KiB) Viewed 11938 times
- Shop_0005.JPG (52.11 KiB) Viewed 11920 times
- Shop_0006.JPG (40.79 KiB) Viewed 11913 times
- Shop_0007.JPG (56.85 KiB) Viewed 11904 times
- Shop_0008.JPG (56.09 KiB) Viewed 11914 times
The posts should fit!cooch366 wrote:Here is my use of an old 500 table. I can use all of my fences on it.
Steve
cooch366
carrage difference
fences fit, but I was mounting it in the carrage. different widths between the 500 and the Mark 7.
Hi Steve,cooch366 wrote:Here is my use of an old 500 table. I can use all of my fences on it.
Steve
I have a 500 that I was going to part out this spring, but keep the table to make a router table. Now I think I'll use the proceeds from the parts to buy a 510 table. Had thought about grinding enough off the bottom of the table to allow the router base to set flush about 1/8" from the top. However, like everything I design in my head before I build, the final product will look nothing like the original!
Thanks for the pictures. They help with the thought process.
Be well,
Ben
I just uncover an area where I had stored a lot of Shopsmith parts many years ago. I found a four 510 tables, two with rails and but only one with trunnion along with several 510 fences. These tables will require a good cleaning as some corrosion has started to occur. Also a Mark VII frame and good looking lower tubes. If anyone just needs a 510 main table, please contact me off-line and I can send pictures.benush26 wrote:Hi Steve,
I have a 500 that I was going to part out this spring, but keep the table to make a router table. Now I think I'll use the proceeds from the parts to buy a 510 table. Had thought about grinding enough off the bottom of the table to allow the router base to set flush about 1/8" from the top. However, like everything I design in my head before I build, the final product will look nothing like the original!![]()
Be well,
Ben
cooch366 wrote:fences fit, but I was mounting it in the carrage. different widths between the 500 and the Mark 7.
Whoops!!!!:o
