My latest restoration project
Thanks! I'm pretty proud of how the lettering on the speed dial turned out. After polishing it, I used a toothbrush and acetone to scrub the old cake batter, gunk, and paint from the recessed letters. Then I used a Q-tip and flooded the recesses and surrounding areas with white Testors model paint (oil based). After letting it set for a few minutes (mostly dry, but still sticky), I wrapped a paper towel around a flat plastic thing I found in the kitchen drawer, dampened it with acetone, and wiped the paint off the surface leaving it in the recesses. I had to do one round of touch up. Pretty easy and it looks great.
Heath
Central Louisiana
Central Louisiana
Thanks for the detail on this - that was my first question on how you got the lettering so nice. I've long wanted one of the old milkshake mixers from the same era and you've inspired me if I ever run across such items that need some TLC.heathicus wrote:Thanks! I'm pretty proud of how the lettering on the speed dial turned out. After polishing it, I used a toothbrush and acetone to scrub the old cake batter, gunk, and paint from the recessed letters. Then I used a Q-tip and flooded the recesses and surrounding areas with white Testors model paint (oil based). After letting it set for a few minutes (mostly dry, but still sticky), I wrapped a paper towel around a flat plastic thing I found in the kitchen drawer, dampened it with acetone, and wiped the paint off the surface leaving it in the recesses. I had to do one round of touch up. Pretty easy and it looks great.
'82 Mark V 500 #96309
- rcplaneguy
newportcycle
This mixer was definitely a workhorse in my grandmother's kitchen. I've eaten many delicious pies and cakes and other items that this mixer had a hand in creating. I'm rather proud I was able to restore it, not just in appearance, but in function which is where its real "life" is.
Heath
Central Louisiana
Central Louisiana
