10ER Shopsmith
- 2centsworth
Wow...
Looks better then new. Great Job.
Jerry Penny
2centsworth
The Woodlands, Tx
SS 520 SN#518424 2000 (reversed motor), Shopsmith 10 E (shorty) fully restored by Skip with DC motor, Shopsmith 10 ER fully restored by Skip with DC motor, Shopsmith 10 ER (under going restoration), Greenie Shorty sanding station, Greenie Mini jointer station, SS Bandsaw power station, SS Planner, SS overhead pin router, SS Belt Sander, SS Strip Sander,, SS Jigsaw, SS Dust Collector, Ringmaster, and still having fun looking for more !
2centsworth
The Woodlands, Tx
Getting Close to finished
just need my friend to help lift it up and bolt it down, and a few odds and ends
- IMG_20140116_184044.jpg99.jpg (227.26 KiB) Viewed 1493 times
- IMG_20140116_184154.jpg99.jpg (157.3 KiB) Viewed 1489 times
- IMG_20140116_184211.jpg99.jpg (180.89 KiB) Viewed 1492 times
Ahem!:rolleyes:
The tailstock is reversed.
The groove for the table mount and knob face the outside. That means the table is also reversed on the mount. . . . And the 2MT socket.
Still very nice. Slick wheels! Good looking 2x6s.
How come ya need a helper?????:D
I do hope you have a tube rest.
Greg, unbolt the extension table from the cast iron mounting leg. Bolt it back on, backwards, but don't tighten down the bolts.
Now, remove the tailstock, and install it so the groove that the mounting leg mounts on, is on the far right (outside) of the machine. Slide the main table and carriage, down so they line up with the ext table. Make sure the 2 tables line up, and tighten those bolts.
steve
steve
Yeah I shoulda told him the table was backwards on the mounting bracket!:o
Like This??
Had some time today.
- IMG_20140117_131339.jpg99.jpg (136.46 KiB) Viewed 1484 times
YES!:):):):)greg1m53 wrote:Had some time today.
Did you also reverse the MT2 tailstock 'socket'?
I see yer 'helper' 'performed'.
Yer gettin' there splendidly.
Thanks JPG
Just took a little while longer than I thought
as I said my mind has not really been on this.
thanks again guys!!
thanks again guys!!
