Sanding disc comes loose.
beeg
Post by beeg »
Also do you have a new power coupler? Somewhere here it's been said that an old one can cause problems when using it on a powerpro.
beeg wrote:Also do you have a new power coupler? Somewhere here it's been said that an old one can cause problems when using it on a powerpro.
I doubt a power coupler will have much effect on a sanding disk!;)
robinson46176
Post by robinson46176 »
I don't have a Power Pro but I have had a few setscrews loosen up over the years. I can't find them locally so I will have to order but I intend to start replacing some of mine with brass tipped setscrews. The flat brass tip against hardened steel acts as a brake (softer material against hard steel). I have used some successfully in larger sizes in high vibration farming applications like self propelled combines and a hammer mill. Actually the hammer mill it wasn't a brass tipped setscrew but a ball of brass made by melting a little off of the end of a brazing rod with the torch and putting the little ball in the hole first and tightening the regular setscrew down on it.
wrmnfzy
Set screw
Post by wrmnfzy »
I replaced it this morning and still works loose. I know I could just have the disc used by it self but the projects I'm working on calls for band saw and sanding. It would be an inconvenience to change back and forth. The brass set screw sound interesting where might they be available? The thing that gets me is that this is a new problem, I have run both bandsaw and sanding disc for years without problems????:confused:
joshh
Post by joshh »
Check for a hairline crack down the length of the threads. I had a hub that did the same thing. I couldn't see the crack without REALLY looking.
- 1986 Mark V 500 Mini
- 1985 Mark V 510 with reversible motor, bandsaw, jointer, and double-tilt.
I offer quality motor reversal, rebuilding, and rewiring. Contact me at HarbourTools@live.com
wrmnfzy
Josh
Post by wrmnfzy »
I tried two new set screws and same result.
joshh
Post by joshh »
wrmnfzy wrote:I tried two new set screws and same result.
Not on the set screw, down the threads they screw into.
robinson46176
This is what a brass tipped setscrew looks like... Note that I didn't look for the proper size, this was just a good picture.
http://www.amazon.com/Pack-Replacement-Screws-Solvent-Adapter/dp/B00COU0ONW
wrmnfzy
Set screw
Post by wrmnfzy »
joshh wrote:Not on the set screw, down the threads they screw into.
I'll check, thanks.
wrmnfzy
Brass set screw
Post by wrmnfzy »
robinson46176 wrote:This is what a brass tipped setscrew looks like... Note that I didn't look for the proper size, this was just a good picture.
[url=http://www.amazon.com/Pack-Replacement- ... B00COU0ONW]http://www.amazon.com/Pack-Replacement- ... B00COU0ONW[/
Thanks for the info, I'll try if I don't find a fixable problem.
