http://www.youtube.com/watch?v=BqHL404zhcU
'nuff said!
steve
Propane costs!!
Here is the latest information from my brother:
We are at about 40 %, we run the new electric heater from when we get up until we go to bed, don't trust running when we are sleeping ! Cost about 15 cents a hour. We keep the house at 68 wear sweat pants etc.Office and bedroom doors closed, rugs under the doors, drapes closed. It was 21 below again this morning.
Still 11 below, catch you later .
This is from this morning.
From Feb. 4th:
Well we have 12.5 below this morning, have the new heater plugged in this morning,5000 B.T.U. Not sure about letting it run all night yet. Used it last night the furnace hardy kicked on. Today have to put anti freeze in washer and put lamp on water pump, because with out the furnace on no heat down stairs.
I would hate it if it got so cold he had to start heating the house with birdhouses, wonder how long 800 birdhouses would last??
From Feb. 4th:
I'm sorry, are you saying that you take two showers a month? Not sure I'd want to go there..........
Sorry I just couldn't help it....
skou wrote:OK, in mid December, I ran the heater, before I took a shower.
Twice.
I've done that again, twice, this month.
It gets down to the higher 40s at night, but
in the mid 6os to 81 since November.
Come back next July, and we'll compare
bills.
steve
Ed, don't EVER change!!:Dreible wrote:I'm sorry, are you saying that you take two showers a month? Not sure I'd want to go there..........
Seriously, I take one a day, just like the vitamins.
Tomorrow's (well, later on today) predicted high is
76.
This August, it'll be 40+ degrees higher.
steve
- robinson46176
We are still buying wood for the wood furnace. I am allowed to cut wood now and feel good enough to cut wood, I just don't want to.
I actually usually enjoy cutting wood but not standing in 4 to 12 inches of snow. I did a lot of it when I was younger but I find myself to be a lot more prone to stumbling now and I try to avoid falling on chainsaws...
We pay $60 for a 4' x 6' face cord, delivered and stacked, and in most weather that will last about 10 days. The last 30 days we have used about 30% more than normal due to silly cold and windy weather. we were also running a little electric heat in some rooms and the light bill showed that nicely.
The normal wood heat only bill is quite reasonable considering that we heat over 4,000 sq.ft. Our one big culprit is our slant wall solar room. It is double glass but at night or cloudy days all of that glass radiates an awful lot of cold air. On sunny days it makes a lot of heat but this year sunny days have been limited.
I need to make some wood frames and put some decent clear plastic glazing on each of the windows in there. All but a couple of smaller triangle windows are 4' x just over 6'. There are 6 of those.
I would never build a room like that again. I like a lot of glass but there are better ways.
Looking at the 10 day forecast for here I hope to be cutting wood in maybe a week or so. I'll still likely keep buying some wood this year since I only have a limited amount of stuff that is dry enough to cut right now. I'll have a lot of tops to cut for next winter and may not need to buy any for next winter. I will also have sawmill slabs to cut for next year and they dry fast if under roof.
I guess the LP guys will just have to get along with out me this year.
I may need some LP for the motorhome. I really wanted to do some late fall camping last year but my dicky ticker had other plans. I might sneak in a little early spring camping if I get a chance. It doesn't take a lot to heat that old motorhome in mildish weather. Maybe we will just use a lot of blankets and fire up the engine and run the vehicle heater a short time in the mornings.
I also have one of these. I wouldn't want to sleep with it going but it works pretty nicely for other times. I originally bought it for and used it in my combine cab where the regular heater failed and was going to be a lot of work and expense to repair and I didn't have the time to give it during the middle of harvest. The little Mr. Heater served quite well.
https://www.mrheater.com/product.aspx?catid=41&id=24
I have not priced the little tanks lately to see if they have gone silly in price. I do have a few on hand.
