That is one possible explanation for the symptom you have described. I recall the standard Incra miter bar is thicker/taller than the Shopsmith miter slot. Compare it to the bar on your Shopsmith miter gauge.ChrisNeilan wrote:I'm starting to wonder if maybe I have the standard (non Shopsmith) model. I'll measure the bar again tomorrow, actually today!
Incra Miter Express question/problem
The saving grace here is that if you have the wrong miter bar, Incra sells the pieces.
http://www.incrementaltools.com/PARTS_I ... xpress.htm
- ChrisNeilan
Dusty, thanks for the link. That will come in very handy over time. I just measured the "utility plate" and it is the correct one. A very little sanding to remove any burrs and a little wax made a big difference. This sled has been unboxxed and floating around my shop unassembled for two years. The guide strips have long since been lost. They would lift the unit just enough to make it perfect. I know I've seen this product somewhere, maybe in a box store. Anyone know where I could pick it up locally? Any substitute?dusty wrote:The saving grace here is that if you have the wrong miter bar, Incra sells the pieces.
Thanks.
This place is a godsend! That reminds me, it's Sunday!
Woodcraft sells something very similar; a self adhesive Mylar strip.ChrisNeilan wrote:Dusty, thanks for the link. That will come in very handy over time. I just measured the "utility plate" and it is the correct one. A very little sanding to remove any burrs and a little wax made a big difference. This sled has been unboxxed and floating around my shop unassembled for two years. The guide strips have long since been lost. They would lift the unit just enough to make it perfect. I know I've seen this product somewhere, maybe in a box store. Anyone know where I could pick it up locally? Any substitute?
Thanks.
- ChrisNeilan
This is a normal occurrence for me but then I am getting old and forgetful. If you can apply that explanation then I would suggest that you do as I do.ChrisNeilan wrote:Woodcraft is about fifty miles away, and naturally I was there YESTERDAY!:mad:
Oh well...
I maintain a "shopping list" of "needed items" over the visor in my truck. When I find myself at Woodcraft, or the lumber yard or....wherever - I check the list.
Don't carry the list in with you. If you leave it there, all that effort is lost.
- ChrisNeilan
dusty wrote:This is a normal occurrence for me but then I am getting old and forgetful. If you can apply that explanation then I would suggest that you do as I do.
At 55 it depends who you ask if I'm old! Forgetfull? I blame it on ADD disorder which I probably have:o
Just remember not to take the other car when you go shopping.dusty wrote:This is a normal occurrence for me but then I am getting old and forgetful. If you can apply that explanation then I would suggest that you do as I do.
Though going to ANY woodworking store is always a fun (and sometimes expensive) trip and I would never dream of asking someone to NOT goChrisNeilan wrote:Dusty, thanks for the link. That will come in very handy over time. I just measured the "utility plate" and it is the correct one. A very little sanding to remove any burrs and a little wax made a big difference. This sled has been unboxxed and floating around my shop unassembled for two years. The guide strips have long since been lost. They would lift the unit just enough to make it perfect. I know I've seen this product somewhere, maybe in a box store. Anyone know where I could pick it up locally? Any substitute?
Thanks.
On Dusty's link. it's part #4 at $1.70 so I don't think that they are losing any great amount of money by sending you one. Even with a couple bucks postage it's less than a gallon of gas.
The strips make a huge difference.
Be well,
Ben
