Upgrade: 510 to 520
billmayo
Upgrade: 510 to 520
Post by billmayo »
The 510 to 520 Pro Fence & Table System Upgrade #555982 and #555983 both lists and shows (8) new extruded Rails for Main and Extension Tables in the 2008 catalog and on the Shopsmith web site. You do need 8 rails.
keakap
Post by keakap »
billmayo wrote:The 510 to 520 Pro Fence & Table System Upgrade #555982 and #555983 both lists and shows (8) new extruded Rails for Main and Extension Tables in the 2008 catalog and on the Shopsmith web site. You do need 8 rails.
Thanks.
Directly cut from the email offer:
"(6) New Extruded Rails for Main and Extension Tables. "
Directly cut from the ShopSmith web site order page:
These are not typos, they are cut and paste. I swear I am not making this up.
keakap wrote:Thanks.
I'm not sure about this at all but I received a pair of rails for the main table and three (3) sets of rails for extension/floating tables.
Here’s what you get with the Model 520
Table System Upgrade Kit:
• Larger Rip Fence is 24 1/2˝ long x 21/2˝ thick
with dual T-Slot Tracks on the top surface
and a T-Slot Track on each Face.
• (2) New Direct-Reading Rip Fence Scales.
You get two magnetic,
stainless steel Scales, one 45˝
long and one 16˝ long. Bottom Page 5
• New, wider Fence Straddler.
• (8) New Rails for Main and Extension Tables.
• Two Floating Extension Tables slide on
Connecting Tubes and lock anywhere you
want them.
• Four 27˝ Connecting Tubes slip through
the Rails and tie the System together with
locking Knobs.
• Two Telescoping Legs give added support.
A quick twist locks their height.
• All required fittings and hardware.
• Instruction Manual.
• (2) special Set-Up and Alignment Gauges.
555986 Model 505 Pro Fence $641.67
& Table Upgrade
Whatever you do, make sure you are ordering the right upgrade kit. This will help to keep you from being disappointed when it arrives and you don't get what you expect.
Remember, a standard Mark V configuration includes only one extension table.
I know you already are very much aware of this, but you DO need a hybrid set(new main table/old float/extension table) of rails.
billmayo
Upgrade: 510 to 520
Post by billmayo »
Call and ask for Linda 1-800-543-7586 and she will make sure you get what you want. Outstanding customer service too.
keakap
Post by keakap »
billmayo wrote:Call and ask for Linda 1-800-543-7586 and she will make sure you get what you want. Outstanding customer service too.
Agree wholeheartedly. Talked to Linda about my "variety pack" (as JPG calls it) of rails and tables, and got it all cleared up. Forgot to ask about "6" versus "8", but no need-- I believe you guys.
About the upgrade kits- parts are the same. If you're doing -982 you change and adjust rails. With -983 you bore out the apron holes, then do the same as -2, basically. (If I'd known that I'd have ordered the upgrade months ago.)
"Outstanding" I agree is a fit descriptor for SS customer service, in my experience.
(next time you talk to Linda, ask her how many arbors were produced under the number 505506, just for kicks.)
beeg
Post by beeg »
Linda should be pretty good. Jan taught her most of what she knows. :)
colday
Got my 520 upgrade today! :)
Post by colday »
I got it this morning about 8:30, all installed & setup in about an hour or so. I had a few interruptions, plus...
I took some PICTURES! :D
For the unboxing people:
[ATTACH]5867[/ATTACH] [ATTACH]5868[/ATTACH]
[ATTACH]5869[/ATTACH]
And the install:
[ATTACH]5870[/ATTACH] [ATTACH]5871[/ATTACH]
The rest will follow...
Steve
2004 50ᵗʰ Anniversary Mark V 520
colday
Post by colday »
And now the rest...
The front:
[ATTACH]5872[/ATTACH]
The back:
[ATTACH]5874[/ATTACH]
All tables from the back:
[ATTACH]5875[/ATTACH]
Nice fit!
[ATTACH]5876[/ATTACH]
My Baby!
[ATTACH]5877[/ATTACH]
I'm extremely pleased at how well this went together & how easy it is compared to the 510 to get aligned. This was well worth the price (I did get it for the sale price).
Now to give the table a good polish & get the Bandsaw tweaked.
Steve
Upgrade: 510 to 520
I am certain that you will be very pleased with the new setup, Steve. For me, it was like getting a brand new machine all over again.
In your pictures I see something that doesn't look right, however. It is probably an obstacle allusion. When you slide the extension/floating tables tight together with the main table, do you have a nice smooth transition from rail to rail (both front and rear). If you don't, you'll want to spend some time tweaking those alignments.
Congratulations.
