iBox left over part
iBox left over part
It is used to hold the small plastic wrench that is used to adjust the pin plate knob. Don't remember where I saw the shot whether in one of the videos of the iBox or just where. I have mine on one of the rear blade guard screws.
tenbears wrote:It is used to hold the small plastic wrench that is used to adjust the pin plate knob. Don't remember where I saw the shot whether in one of the videos of the iBox or just where. I have mine on one of the rear blade guard screws.
The video suggests putting the micro adjust tool here
where you said you keep yours
[ATTACH]25000[/ATTACH]
- Adjust knob.jpg (111.9 KiB) Viewed 1525 times
Bruce
Ok Ok, I'm up to four now...
- ChrisNeilan
Post #11 suggested the part in question was to hold that downChrisNeilan wrote:That is not the part in question.
I was illustrating that they suggested another way.
Bruce
- ChrisNeilan
- pieceseeker
I just opened mine to see. Haven't had the chance to try it out yet. Here's the way I found the spacer in question. Turns out Mike is right about it protecting the threaded shaft.
[ATTACH]25001[/ATTACH]
[ATTACH]25002[/ATTACH]
[ATTACH]25003[/ATTACH]
And JP is correct on the dimensions.
- I Box 1.jpg (38.02 KiB) Viewed 1517 times
- I Box 2.jpg (35.74 KiB) Viewed 1517 times
- I Box 3.jpg (47.35 KiB) Viewed 1517 times
THANX
Now I know I didn't mess up assembly. Mine was not protecting anything
I remember seeing it almost first thing when I opened the box.
It's being out of place did not result in any harm though:)
Bruce
- pieceseeker
Yea, there's still at least a double layer of cardboard before it could pierce the outside of the box.
Other alternatives for shipping purposes, would have been to use a rubber vacuum cap over the stud that would fit snug and not fall off.
Or use a "threaded" nylon spacer. But hey, back seat drivers can always find different ways to the same destination.
If it were not for back seat drivers on this forumpieceseeker wrote:Yea, there's still at least a double layer of cardboard before it could pierce the outside of the box.
