Loose Set Screw
When attaching to the quill shaft, I wiggle the wrench back and forth while tightening. This finds the flat spot. The arbor(or whatever) moves more easily than the shaft etc.
For set screws I have been grinding off the cup point thus making them flat point. The ss tool kit will hold the screw in position against a sanding disk laying flat against the table and against the miter gauge.
I do not recall throwing any away. I lose them all to easily by dropping.
As for Steve, realize his set screws are a size bigger(3/8-16?) as is his wrench(3/16).:)
JPG40504 wrote: As for Steve, realize his set screws are a size bigger(3/8-16?) as is his wrench(3/16).:)
I don't need to know that and I assume that those people (10E owners I guess) who do need to know already know.
dusty wrote:I don't need to know that and I assume that those people (10E owners I guess) who do need to know already know.
So how about the rest of the world?;)
Point being the bigger screws tightened with a larger wrench will naturally have less of a tendency to come loose.
I have not and will never state that I do not have a need to know anything.
I may find new info disgusting or worse, but do not think I need to be ignorant of same.
Neither do I consider it appropriate to keep others in ignorance by failing to lead them to light!:cool:
So lighten up Dusty.:)
JPG40504 wrote:So how about the rest of the world?]
You do a pretty good job of taking care of the "rest of the world". It is all that I can do well to take care of myself and my own needs.
SDSSmith
Post by SDSSmith »
JPG40504 wrote:When attaching to the quill shaft, I wiggle the wrench back and forth while tightening. This finds the flat spot. The arbor(or whatever) moves more easily than the shaft etc.
Actually, many of the arbors (1/2" and 5/8") originally made for the model 10 use a smaller set screw than the 5/16" set screws found on the Mark V accessories and utilize a 1/8" allen wrench to tighten. The model 10 drill chuck uses a larger set screw than its Mark V counterpart.
Rob in San Diego
gr8mesquite
Post by gr8mesquite »
In response to some questions, I bought a box of set screws from SS some time back. I put a new one in yesterday...appeared to be cupped.
I am centering on the flat, and I've re-dressed the flat with a fine/medium file.
I am tightening aggressively, but all this to no avail. After a bit, I get play in the chuck.
I wondering if I should look for knurled cup points somewhere.
Thanks
Jerome
"Life is what happens to you while you're busy making other plans."
beeg
Post by beeg »
gr8mesquite wrote:In response to some questions, I bought a box of set screws from SS some time back. I put a new one in yesterday...appeared to be cupped.
I thought that per Dusty's listing it should be as follows.
Saw Arbor 319 222458 5/16"-18x1/4" Black Oxide Alloy Steel Flat Point Socket Set Screw"
gr8mesquite
OK...I'll look for one of those.
Jerome
Loose Saw Arbor (Spindle) Set Screws
beeg wrote:I thought that per Dusty's listing it should be as follows.
Saw Arbor (319), the Shopsmith parts lists call for part number 222458 (set screw 1/4" long).
Drill Chuck (299), the Shopsmith parts list calls for part number 222460 (set screw 3/8" long).
The Help Kit supplies 20ea of one type and 6ea of the other and does not tell where to use them or identify the point type.
I prepared and published on this forum a list, a long time ago, that based on an inspection of my equipment identified the set screws with regard to point type. I believe that both of these set screw part numbers are for flat set screws(differing only in length).
What is in the Help Kit?
Mike907
Post by Mike907 »
These posts made me curious, so I went and checked all of my saw arbors (8) and drill chucks (2), and all set screws are flat point and match Dusty's list. The set screws in the two 5/8" saw arbors are 3/8" long and have what looks to be flat brass tips. I wasn't able to find a part number for those set screws.
