Won't turn on fate turning off
kcmoore
Post by kcmoore »
Is that secondary switch like a solenoid? There is a familiar bump on the side of the motor that looks like my old VW starter solenoid. I used to have to tap on that thing to get it to turn the engine over. But, I could hear a clicking also. This one makes no sound.
Do you have a way to check electrical continuity or measure resistance?
No hum indicates power is not getting to the motor.
Again, are the wires still attached to the power switch?
kcmoore
Post by kcmoore »
Yes. I'll check the power at the switch.
kcmoore wrote:Is that secondary switch like a solenoid? There is a familiar bump on the side of the motor that looks like my old VW starter solenoid. I used to have to tap on that thing to get it to turn the engine over. But, I could hear a clicking also. This one makes no sound.
That 'bump' is a cover over the start capacitor. If no hum, it is not suspect.
kcmoore wrote:Yes. I'll check the power at the switch.
Careful, it is safer to be checking continuity/resistance(not plugged in).
kcmoore
Post by kcmoore »
Ok, the switch has 4 wires coming into it, 2 white, 1 black, 1 blue. There is power to the black and one of the white. I unplugged it and did an ohm check across the whites. It is open when off, shorted when on. The black and blue don't ohm out to anything. Seems like the switch is good.
kcmoore
Post by kcmoore »
Or is the switch bad? White and black in, white and blue out to the motor. Yet I don't get continuity between the black and blue terminals when it is on. Seems like the switch is the culprit.
Agree?
kcmoore
Post by kcmoore »
Ok, I went out and cycled the switch a bunch of times. I the. Plugged it in and tried turning it on forcefully and it powered up. Wonky switch!
Thanks for asking me the leading questions to get me thru this!
kcmoore wrote:Ok, I went out and cycled the switch a bunch of times. I the. Plugged it in and tried turning it on forcefully and it powered up. Wonky switch!
As a quick(temporary) fix, remove the white wires and connect them to each other manually. Move the black and blue wires to the terminals where the white wires 'were'. Rewire correctly when switch replaced.
wa2crk
Post by wa2crk »
