Ed,Ed in Tampa wrote:In my opinion the upgrade to the 520 is a lot more than a Pro fence.
The way the connection tubes interact with tables is where I see the biggest improvement.
With the 510 the tightener to the connector tubes came from the side and the table could be aligned exactly centered, too high or too low. It changed depending on how you held the table and connector tube.
This misalignment cost me two ruined projects. It frustrated the ever loving crap out of me!!!!!!! I hated it!!!!!!! And to me it made an excellent machine the 500 a piece of junk.
I hated it so much that I stopped using my Shopsmith altogether. Would have sold it to the first person that offered me more than $1. It sat unused for nearly 15 years. I actually rented time on other machines to accomplish what I wanted and was actively seeking to replace it with stationary machines. At about this time my SIL bought a Unisaw so I just shifted to it.
Then I saw the 520 the connector tube tightener comes up from the bottom. The table is always pushed down the tube always up. It never changes. Once properly setup the table always are exactly lined up. Perfectly.
That made me fall in love all over again with my Shopsmith.
As for the Pro fence I actually liked the 510 better but I will admit adjusting the pro fence is far easier.
My opinion the 510 upgrade was ill conceived, ill executed and should never have been built. I believe it did more damage to Shopsmith than anything else Shopsmith ever did.
Had I never owned a 500 or 520 I would be first to declare Shopsmith made only junk, that is how bad I view the 510.
Don't get rid of your track saw, it is far superior to anything when cutting down sheet stock or squaring an edge. Only competition I know for it is a high end panel saw or big buck CNC machine. It would cost a least $30,000+ to get the quality of cut and accuracy of a Festool or Eurekazone track saw.
I'm a huge fan of the Eurekazone products. I have a couple dozen feet of track (bought a bunch of track plus other extrusions during their pre-move sale), B300 bridge, SSRK, UEG (the only component I've been less than thrilled with), and RipSizer (the successor to the UEG).
I also have a decent sized CNC router. And an almost 24x36" (600x900mm) laser engraver.
Thanks for your thoughts on the 510 vs 520 table connections. I'll definitely keep that in the mind as I start using it. I can definitely see how that could be a problem, and was actually wondering about it as I was putting the table back together following its move.
At this point, I don't know how much I will use connected tables, especially needing to be dead flat. One of the main reasons I'm looking at it for tablesaw purposes is that I might explore segmented turning, which needs lots of little but precisely angled pieces. I'm not sure I could get the high precision I need using the tracksaw, more from vertical issues and blade flex. While the CNC could do it, it would take longer than doing on the SS plus the CNC might throw the little pieces as well as using more wood.
