New wire to ER Motor?
- "Wild Bad Bob"
reible,
unless I MISSED something, on the Menards link
http://www.menards.com/main/electrical/ ... c-6324.htm
Where did that come from,from you!!!!!!!!!!!!!
- "Wild Bad Bob"
reible's Avatar
reible,
rethink it all!!!!!!!!!!!!!!!!!!!
reible,
I don't know this switch but I can read and the first thing I saw was this:
[ATTACH]26101[/ATTACH]
You do not want a momentary switch for this application. So if the Menards label is correct then this is a momentary switch, if their label is wrong then the next question was barrel length. You should have room for a nut on the inside, followed by a lock washer then the housing and the final nut.
Go to the store and see if it spring loaded to center or if it will stay in either on position with out being held. If it stays then the menards page has the wrong label.
I would still not use this switch because I'd like a simple toggle on/off with out a center position.
- ScreenHunter_138 Sep. 03 20.50.jpg (43.56 KiB) Viewed 2052 times
- "Wild Bad Bob"
I was at a Fleet Farm next to Menards today!! Switch in stock, okay, center, off, lower one continuously on. up, momentarily on/jog. My ? is can an induction motor handle that?
- "Wild Bad Bob"
SEE, if you went to "Discription" you wood have been on the same page as me!!! And no FYs!!
- "Wild Bad Bob"
Yes, LOOK AT IT!!!!! ON MOMENTARY/OFF/ON!!!!! IT TELLS YOU ALL!!!!!!!!!!!reible wrote:I don't know this switch but I can read and the first thing I saw was this:
- "Wild Bad Bob"
Dont Let Me Get Hencle Involed Here!!!!
- rcplaneguy
- "Wild Bad Bob"
- "Wild Bad Bob"
Center id off. down is on, to turn off go back to center, like a normal switch, now I am doing turning/lathe work,, I chucked up a heavy, I want to get it centered, I just have to flip the switch "up" spring loaded, "jog/momentarily to get a turn on it.
