Need Some Help
forrestb wrote:For instance, I have one that positions the blade to the very left of the standard insert. That allows me to have fairly good dust collection (at least, better than a ZCI) and still cut off a thin strip without worrying about the strip going 'down the tube.'
Hmm. I think the dado insert would be better - just have to mill out a place for the riving knife.
Thanks to Dusty and Dennis for making me think - again.
Forrest
Forrest,
Please give me the dimension with your wooded stopper in place and tell me how thick the stopper is. I can go from there. Thanks.
Afterthought: In addition, please give me the dimensions from the plate to the table saw insert cut out on each side of the blade. Mine measures 1.5" on the left side.
fitzhugh
Post by fitzhugh »
Dusty, do you need more measurements to compare? I can't check now without waking up others but if you need more I'll check tomorrow. I have an 82 Mk V 500. I also have a greenie - the quill may or may not be in it.
Forrestb - I like that solution for the stop tube/block.
EDIT: oh, didn't realize this was already over a week old. I suspect you have the information you need.
Greenie (no serial #), 82 Mark V 500 serial #128648, ci bandsaw, old jigsaw, planer. All one buy in March 2014. Magna Jointer added Nov. '14. Speed reducer, conical disk and two bearing quill upgrade.
