mountainbreeze wrote:I could use a little more information. How far below the fill hole would be considered so low that there could have been damage?
Also, does this saw use SS only blades or does it use blades readily available from other sources (Lowes/HD/Woodcraft/Rockler/etc.).
Do not worry about 'how low'. Just fill to the hole.* If damage has been done that is a fact. You just need to prevent it.
Any 5" pinless blade should do. Pins can be removed.
* It needs to be 'mounted', not laying on it's back.
