Just went on Amazon.com and found these
https://www.amazon.com/Light-Milling-La ... 33&sr=8-33
I want a work light similar to the Shopsmith
Re: I want a work light similar to the Shopsmith
The Shopsmith lamps, made by Moffatt, are rated for a 100w incandescent, or equivalent, which produces 1600 lumens. The linked lamps are only 350 lumens, and the larger one, 500 lumens. They may not provide as much illumination as you would like.
I agree, SS lights are made for an incandescent bulb and are designed to reduce the heat you feel if you touch the shade. They work very well for that. They also look very nice.Mike907 wrote:The Shopsmith lamps, made by Moffatt, are rated for a 100w incandescent, or equivalent, which produces 1600 lumens. The linked lamps are only 350 lumens, and the larger one, 500 lumens. They may not provide as much illumination as you would like.
Now that LED bulbs have come down drastically in price I have replaced the incandescent bulbs in my SS lights with LED's. Of course that negates the necessity of the cooling fins in the SS lights.
Having said that they are quality lights and I would buy another one if I needed one.
- rlkeeney
You might want to consider these Harmiey Sewing Machine Light (40LED) 8W Gooseneck Work Light with Magnetic Mounting Base White Soft Light for Lathes Drill Presses Workbenches.
https://www.amazon.com/harmiey-Goosenec ... 07N1MK51J/
I have four in my shop. Two are mounted on my scroll saw. They never move. I have other lights that cost many times more that are not near as good.
Robert Keeney
Tallahassee Florida USA
Robert Keeney
Thanks Robert, I'll get one to check out. Seems like an inexpensive option.
I built up a nice rig, inspired by an Adam Savage build, but it definitely wasn't cheap at something around $80+. This is his build video, https://www.youtube.com/watch?v=JL3uZ88vA_0. I used a bit better LED light and used a couple pieces of microphone gooseneck and adapters instead of the line loc that Adam used. If anyone is interested, let me know and I will post the components I used.
Roy
Home designed and built CNC router, another CNC router
desktop size, Avid 5x10 Pro CNC w/ATC, CNCed G0704 milling machine
Laser engraver
Way too much other stuff and not enough space
Laser engraver
