Mark 7 Set-up
jimsteinmetz
Re: Mark 7 Set-up
Post by jimsteinmetz »
Finally getting back to this.
I re-aligned the table as Dusty suggested and now the blade is right in the middle of the table insert. I found this to be directly in the center of the table adjustment. So that one is solved!
I spent some more time with the table insert and found it was bowed front to back, side to side, up and down and any other direction you can think of. I suspect that at one time it was sat on, stepped on, pried on, etc. I ended up making a ZCI and used the set screw adjustment suggested by algale. That works fine and no more hang ups especially when cutting small pieces.
Thanks to everyone for their help and suggestions.
Jim Steinmetz
