Reducing it to one hand should minimize the need for 'coordination'.BuckeyeDennis wrote:Got it. My problem to date has been keeping those skinny wrenches on their respective nuts. We'll see if I'm sufficiently coordinated with the aid of "the trick".reible wrote:The trick is to always squeeze the wrenches together. This works for both tightening and loosening, yea really.
Router Quick-change Collet
Re: Router Quick-change Collet
Yeah but only if you position the wrenches properly.JPG wrote:Reducing it to one hand should minimize the need for 'coordination'.BuckeyeDennis wrote:Got it. My problem to date has been keeping those skinny wrenches on their respective nuts. We'll see if I'm sufficiently coordinated with the aid of "the trick".reible wrote:The trick is to always squeeze the wrenches together. This works for both tightening and loosening, yea really.
It's for sure that I'm not! I've tried it several times with the PC in the RT and they always slip off. But, then, I'm using "bent" wrenches.
If you are not coordinated you might not want to use power tools or much else.JPG wrote:Reducing it to one hand should minimize the need for 'coordination'.BuckeyeDennis wrote:Got it. My problem to date has been keeping those skinny wrenches on their respective nuts. We'll see if I'm sufficiently coordinated with the aid of "the trick".reible wrote:The trick is to always squeeze the wrenches together. This works for both tightening and loosening, yea really.
My Bench Dog router lift raises the PC 7518 router moter above the table so no need for the adapter.
