Wiring a 240V circuit
tdubnik
Re: Wiring a 240V circuit
Post by tdubnik »
dusty wrote:When you measured the 238 vac, was the circuit loaded (power tool plugged in and running)?
If not, I suggest that you do that. With no load, there will be MINIMAL (if any) LINE LOSS.
Nothing plugged in. I'm picking up the machine on Tuesday and won't have anything to plug in until then.
I found this jointer on Craig's List and worked out a deal. This will solve my jointing of larger pieces for a while.
algale
Post by algale »
I hope you (1) have help to move it and (2) a ground floor shop.
I have the six inch Grizzly jointer and while I had help getting it into my van, the only way I could get it out of my van and into my basement was by taking it apart in the van. Even then it was heavy moving the tables.
tdubnik
Post by tdubnik »
algale wrote:I hope you (1) have help to move it and (2) a ground floor shop.
Yea, I know: BUT I have a plan.
The jointer is supposed to weigh in at around 500 lbs. The place I am picking it up has a loading dock and the owner says we can get it on the truck with no problem. Once I get it home, my shop is in the basement. When I built the house I had an overhead door installed. Plenty of room to get the jointer through.
My neighbor runs a wrecker service so I'll have him bring a tow truck. We'll use some lifting straps to lift it off the truck and set it on the concrete floor just inside the door. It has a mobile stand so I should be good from there.
I also hope it measured half that to 'ground' from each 'hot'.
#12 is quite adequate.
tdubnik
Post by tdubnik »
It did because I checked. :)
