New PowerPro
Re: New PowerPro
claimdude wrote:I am no electrician but I took a 240 drop and split off a couple of 110s. Only one tool on the circuit is used at time and I left it all tied to the 220 breaker. may be a huge no-no but it has worked for me.
Jack
I doubt the 'drop' had four conductors(HotA,HotB,Ground,Neutral).
As for the no-no, the ground is likely not separate from the neutral.
As for being tied to a 230v breaker over current protection still exists.
To make it 'meet' code, a separate ground should be added.
rjent
Re: New PowerPro
Post by rjent »
colday wrote:I'm starting to rethink my thinking! :rolleyes:
It seems if I run a 240 drop I will actually loose more than I will gain:
  • The drop can only be used by the Shopsmith (I have no other 240v tools)
  • The 240 breaker will take my last spot in the panel
And then the plusses of using a 120 drop:
  • A 120 drop can be used by several other tools
  • A 120 drop will only use one slot
  • I will have one spare slot for later use
The 240 drop will only give me the ¼ HP gain, and for what I do that isn't really worth it.
Steve
Trust me, I am no expert, but you do NOT need the 240 supply to this machine. You will slip the belts running on 110 as it is .... (Yes I tested that when I first got mine. I put it in DP mode and put an 80 grit sanding disk on it and pinched a 2x12 between the table and the disk by lifting one end. It did slip the belts and some RPM loss. Very impressive)
JMHO
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
Re: New PowerPro
Steve, I have been running my PP on 110V for several years and have noticed no need for more power. In my last large project I was ripping 8/4 black walnut.
colday
Re: New PowerPro
Post by colday »
Well I stopped by the customer service desk at Lowe's today and found my PowerPro was shipped yesterday from Shopsmith, and should be here in about 2-3 weeks! I did decide to go with a 120vac drop.
I've been making way more sheet rock dust this summer than sawdust, but now I'm on to painting, then cutting and polishing a few granite tiles and that project will be done.
Man I hate muddin and taping!
colday
Re: New PowerPro
Post by colday »
It's here!
paulrussell
Re: New PowerPro
Post by paulrussell »
Congratulations -- you will love it. As long as it took me to decide on mine, I've never regretted it for a minute!
Bruce
Re: New PowerPro
Post by Bruce »
Still waiting on mine. Hopefully it will be shipped in the next few weeks.
Re: New PowerPro
colday wrote:It's here!
Congratulations on your PowerPro.
I see that it came with a nicely bound manual. Does that manual or any other documentation that came with the PowerPro contain a detailed parts breakdowm?
Re: New PowerPro
Let the good times roll! I know I like what my investment is providing and have a second upgrade unit on order. Let us know how its working once you have it making sawdust.
colday
Re: New PowerPro
Post by colday »
Yes, it did! That said the manual is rather thin, but it does have error codes explained, and the parts breakdown. What else is really needed on a complete new headstock?
I hope to get away from the kitchen/dining room remodel to play with it. Unfortunately I don't have any leave left for this year, so I only get the weekends to work in the shop. It is on the way tubes, but now I've got to do an alignment before I can use it. It sure purrs!
Steve
