Bow making question
Re: Bow making question
algale wrote:
JPG wrote:
Ed in Tampa wrote:
.............Beeg said:I just saw on PBS, Woodsmith shop. They used contact cement for glue up of a tambour door. Which wood flex a lot.
the wood on tambour doors does not flex. Narrow pieces of wood are glued to canvas and any flexing is the canvas that is between the wood strips. Like a hinge.
The old timey tambour doors had a cylinder and trough shape on opposite edges and no canvas. Also thicker by necessity.
I don't know what you mean by "old timey" but when tambour was introduced in the late 18th Century it was thin and glued to cloth. Maybe you refer to "roll top" furniture which is a later development.
I stand corrected. :o I was indeed thinking of roll top desk etc..
So make that Mid timey? Or just plain a different animal!
james22
Post by james22 »
I think that would locate the 'flex' where it is least desirable .
It places the "flex" where is is needed!
Hobbyman2
Post by Hobbyman2 »
Easy to mix, easy to use. For all laminated bows. Works for bamboo backed bows too. This is the epoxy that nearly every bowyer in the United States uses. For use on fiberglass laminated bows and any other wood-to-wood or wood-to-bamboo applications. Sold as a 2 pint set (one pint part A and one pint part B). https://www.3riversarchery.com/smooth-o ... -glue.html
This is supposed to work well to . Bowsmith epoxy
https://www.ebay.com/itm/312732985485
Hobbyman2
Post by Hobbyman2 »
UD DPT OF AGRICULTURE
Glues for wood in archery use
https://www.fpl.fs.fed.us/documnts/fplt ... 6-1952.pdf
DLB
Post by DLB »
JPG wrote: Thu Jul 09, 2015 1:10 pm
beeg wrote:I just saw on PBS, Woodsmith shop. They used contact cement for glue up of a tambour door. Which wood flex a lot.
I think that would locate the 'flex' where it is least desirable. ;)
james22 wrote: Wed Jun 23, 2021 4:43 am I think that would locate the 'flex' where it is least desirable.
I'm thinking SPAM is on the menu... ;) This is/was james22's first post and follows a recent pattern of reopening an older thread with copied content. We'll know for sure when 'he' edits the post.
DLB wrote: Wed Jun 23, 2021 6:44 pm
Exactly my thought!
JPG wrote: Wed Jun 23, 2021 11:30 am It places the "flex" where is is needed!
"it" is also modifying quotes.
But then, maybe DLB messed it up????
DLB
Post by DLB »
JPG wrote: Wed Jun 23, 2021 7:29 pm
Always possible and sometimes likely. But I (along with the new member) was quoting an earlier entry of yours from July 9, 2015, not the one from today. Different context for sure.
DLB wrote: Wed Jun 23, 2021 8:03 pm
Look (back) again! My 'later' quote was of my ORIGINAL post that got modified in your post.
Ya got two quotes jumbled. ;)
