Sanding Belts
greitz
Re: Sanding Belts
Post by greitz »
Just a clarification- Shopsmith sells aluminum oxide sanding belts for the belt sander up to 320 grit.
http://www.shopsmith.com/ownersite/cata ... gbelts.htm
Gary
algale
Re: Sanding Belts
Post by algale »
greitz wrote:Just a clarification- Shopsmith sells aluminum oxide sanding belts for the belt sander up to 320 grit.
Gary
I had not noticed that, thanks for posting.
Re: Sanding Belts
Like Dusty, I have never used the belt sander to flatten sharpening stones.
I doubt it would be successful except for very severe cavitation on older(softer) stones and doubt a flat surface would be the result. The belts are too soft/flexible.
I read your initial post just prior to leaving town for a few days. Sorry I could not respond then.
The belt sander is intended for use in rapid material removal(shaping) so finer grits are inconsistent with that.
ddub
Re: Sanding Belts
Post by ddub »
Gary
I purchased my belts a couple of years ago, and I didn't think they did at that time, or I was just confused with the disc sander because they only go to about 120/150 there depending on the type. Sorry for the misinformation.
lightnin
Re: Sanding Belts
Post by lightnin »
I use this for flattening stones. I'ts kinda pricey but works fast and does an awesome job.
I had many stones in need of attention so I dug down a bit deeper in my pockets and
I got one of these. I'm pleased with the results I get with it.
https://www.youtube.com/watch?v=RNspvro ... tu.be&hd=1
