Paulz Nutz -- my version of Shopsmith T-Nuts
paulrussell
Re: Paulz Nutz -- my version of Shopsmith T-Nuts
Post by paulrussell »
JPG wrote:A 'secret' to avoiding breaking taps is the alignment of the tap to the pilot hole.
Which is why I decided to try using the drill press mode.
At first I mounted a sanding disk to the opposite end of the quill shaft and did one manually, using the sanding disk as a handle (power off of course). I then decided to give it a go with power, and by inspiration or luck, it worked great.
