Oh yea, duh, forgot about that.algale wrote:You can't connect the main table to the aux table when using the conical disc, since the main table needs to be tilted to approximately 4 degrees to the left left in order for it to be square to the conical disc surface. But your point about rigidity is still a good one. If you try to take a big bite with the conical disc, there's a chance the table is going to deflect. So use the right grit and take light passes.BuckeyeDennis wrote:For some reason, the video that algale posted won't play for me right now. So this may be redundant. But keep in mind that the SS main table is not terribly rigid in the horizontal direction. So, whenever you are doing an operation that needs a close tolerance in the horizontal direction, you want to stiffen it up. Assuming that you have a 510 or a 520, this is easily accomplished buy mounting the auxiliary table, and coupling it to the main table with the connector tubes. Somewhere there's a video of Nick doing this and using a dial indicator to show the improvement.
I suppose that one could just butt the main table up against the aux table, and get some improvement in stiffness.
