Two Bearing Quill
benmcn
Re: Two Bearing Quill
Post by benmcn »
The bearing is essentially pressed between the spindle side of the shaft and the sleeve. In other words the splines are wider than the inner race, I can't drag the bearing that way (it would leave the inner race behind). It appears that I have the same problem trying to pull the bearing the other direction.
benmcn
Post by benmcn »
Maybe this photo will help. The bearing rests against the splines. I can't pull the bearing this direction. The same relation ship exists on the other side with the couple sleeve.
spline side close up2.jpg (243.8 KiB) Viewed 13400 times
Need a real closeup pix of the 'spacer'/shaft at the quill shaft end.
Question is, how was it put together initially?
BTW have you determined it was the bearings that 'clicked'?
benmcn
Post by benmcn »
Here is a close up of the sleeve side of the spindle assembly. Notice how the inner race almost completely covered by the sleeve. Unless the sleeve can be removed I don't see how to replace this bearing. Maybe that is why I was told it can't be repaired.
sleeve side close up2.jpg (212.64 KiB) Viewed 13393 times
benmcn
Post by benmcn »
Bearings were definitely shot. They spin like roller skate wheels and the roughness is palpable.
Closeup of the quill shaft/'spacer' end.
algale
Post by algale »
It certainly is a puzzle how it could have been assembled in the first place. I'd order a new two bearing quill. Then do a little destructive testing on this one to see how the heck it was built.
wa2crk
Post by wa2crk »
Yes. At least it was on the Craftsman.
Bill
P.S. If you notice on the photo of the front side of rear bearing there is less of the inner race showing than on the photo showing the rear side of the same bearing. This finally tipped me off that it was pressed over the splines. At least that proved to be the case on the Craftsman
PPS Look at the last 2 photos in the post @ 14:24 hours
benmcn
Post by benmcn »
I am no artist, and haven't figured out how to use the CAD programs, but here is a low tech drawing of how I think this think was put together...
It looks like the inner bearing was pressed on to the side of the shaft with the spline. The splines serving as the stop or rest.
Next I imagine the business side of the shaft, which consists of the sleeve, outer bearing rest and tapered shaft were probably pressed onto the shaft with the splines and inner bearing. The inner bearing race or end of the shaft serving as the stop /rest. I remember Jacob Anderson in his headstock rebuild video saying that this was epoxied together
At this point the outer bearing might have been pressed on.
quill drawing.jpg (60.65 KiB) Viewed 13390 times
benmcn wrote:I am no artist, and haven't figured out how to use the CAD programs, but here is a low tech drawing of how I think this think was put together...
Makes sense (except for the non-repairable part! :mad: ). Why did it need to be epoxied?
