Serial Number
Re: Serial Number
I'm not following you guys at all.
The serial number is said to be SS7629.
Yes, it is possible that a number (or 2) got dropped somewhere but it is also possible that the serial number does not follow the Shopsmith convention of the day (which was a four digit serial number).
Does any member of the forum have a machine whose serial number is alpha numeric?????
Re: Serial Number
Two quick things.
1) we have seen SSXXXX numbers here before
2) note the Tipp City on the plate and shopsmith inc
Conclusion Sometime between 1972 and 1978.
beeg
Re: Serial Number
Post by beeg »
06095windsorjmb wrote:I previously inquired about what model my valued SS was. Looking at the nameplate, I have determined that the unit is a Mark V. While doing preventive maintenance I was able to determine that the unit is equipped with a 1 and 1/8 HP motor.
Thank you. Jim Bennett [jmb51@yahoo.com]
The nameplate wood only tell ya the serial number, which you can use to tell when it was built.The model type depends on the table size.
Re: Serial Number
dusty wrote:I'm not following you guys at att.
Have we ever seen an actual picture of a SSXXXX number?
Re: Serial Number
Yes.
Re: Serial Number
Yes.
So can we assume from that is is an early Magna America number? Nothing on the SS site shows that.
Re: Serial Number
Notice what followed the word 'Mark' to the left of the SN? That ain't no "V". IIUC the SS distinguishes the initial SS Inc. production from their predecessors.
Yes I think early SS Inc. production close to 1972.
Seems some folks are getting their knowledge base expanded! :D
Now that did not hurt too much did it? ;)
Re: Serial Number
Again this time with a picture. This is a shopsmith.inc machine, it right on the label. It is also an early machine do to the tipp city location.
This is the tag from the pdf that was provided.
Re: Serial Number
What I miss is the bottom of the vent plate. I saw both those details the first time. All this babbling about the SN. A reveal of the bottom of the vent plate would likely have avoided all that. I see no reason to question the posters ability to read the 'SS' sn. What I would like to see is the Mark "5" at the bottom left.
I am also sure it reveals the motor size without requiring a look inside.
ERLover
Re: Serial Number
Post by ERLover »
@JPG>Wonder what the bottom of the vent plate looks like! :rolleyes:
My thoughts too, but I was waiting for Dusty to ask ;)
