Caster Installation Guide & Drill Bit p/n 556425
Re: Caster Installation Guide & Drill Bit p/n 556425
The drill bit supplied was 9/32 but the holes are NOT all the same. The middle hole, which is used to bolt the jig on through the old upper caster hole is very obviously smaller than the the other 2 holes in the jig.
Yes that is a puzzle - what did you insert into it to locate to the second 'original' hole?(note I edited 'all holes the same' post)algale wrote:The drill bit supplied was 9/32 but the holes are NOT all the same. The middle hole, which is used to bolt the jig on through the old upper caster hole is very obviously smaller than the the other 2 holes in the jig.
The caster instructions say to use one of the supplied Phillips head fasteners (machine screw?) and keps nuts. I believe the locating hole is small and makes a tight fit with the fastener to reduce play in the jig when drilling the holes. The pin is also a close tolerance fit.JPG wrote:Yes that is a puzzle - what did you insert into it to locate to the second 'original' hole?(note I edited 'all holes the same' post)algale wrote:The drill bit supplied was 9/32 but the holes are NOT all the same. The middle hole, which is used to bolt the jig on through the old upper caster hole is very obviously smaller than the the other 2 holes in the jig.
So the supplied screws must be slightly undersized.(<.245)algale wrote:The caster instructions say to use one of the supplied Phillips head fasteners (machine screw?) and keps nuts. I believe the locating hole is small and makes a tight fit with the fastener to reduce play in the jig when drilling the holes. The pin is also a close tolerance fit.JPG wrote:Yes that is a puzzle - what did you insert into it to locate to the second 'original' hole?(note I edited 'all holes the same' post)algale wrote:The drill bit supplied was 9/32 but the holes are NOT all the same. The middle hole, which is used to bolt the jig on through the old upper caster hole is very obviously smaller than the the other 2 holes in the jig.
That makes no sense since the original hole(in the leg) is larger.
The locating is accomplished with the pin. The second 'locating' hole serves to keep all 4 holes on a common center line). Slight deviation is not likely a significant problem.
In any event a tremendous improvement over previous 'debacle'(s).
Thank you for the time and effort expended. You have answered my question which was "Does the new jig differ significantly from the original template". In my opinion, it does not. Therefore, the template, if you have one, is adequate to perform a proper installation BUT only if you have the final template. There was at least one template that was incorrect.
- tomsalwasser
You're right Dusty. The jig makes it really simple to do though, either Shopsmith's or Bill Mayo's.dusty wrote:"Does the new jig differ significantly from the original template". In my opinion, it does not.
Tom
As did mine for me.tomsalwasser wrote:You're right Dusty. The jig makes it really simple to do though, either Shopsmith's or Bill Mayo's.dusty wrote:"Does the new jig differ significantly from the original template". In my opinion, it does not.
Tom
- tomsalwasser
No doubt it's true Dusty. I know you have better drill skills than me. I always send that bit skidding around the target but the jig keeps it in place.dusty wrote:As did mine for me.![]()
Tom
Have ya tried putting a dimple, with a punch. On the mark ya want to drill?tomsalwasser wrote:I always send that bit skidding around the target but the jig keeps it in place.
Tom
beeg wrote:Have ya tried putting a dimple, with a punch. On the mark ya want to drill?tomsalwasser wrote:I always send that bit skidding around the target but the jig keeps it in place.
Tom
Then drill a small pilot hole and gradually increase drill size on subsequent drilling.
