Homemade Dust Extractor
megastevo81
Re: Homemade Dust Extractor
Post by megastevo81 »
Thanks everyone for your kind words. Its nice to have your work appreciated by such a talented group of people. I sent a picture to my uncle who is also a keen wood worker, he described it as a piece of "practical art"
When I started out building the cyclone (12 months ago :( )it was only going to be a timber cyclone with a plastic bin and have flexible hose connected from the blower.
If I had planned this end result I would have taken lots of photos, I found one of the strips layed out to roll up the funnel.
peterm wrote:Marty
JUST WOW!
Did you follow a published plan?
I didn't have a plan to work off, I read somewhere a while back that 11 degrees was the best taper to have on a cyclone, not sure if that is true but I aimed for that. It consists of 35 (should have been 36 but I miss measured a little bit) strips cut on a 5 degree angle on the edges and tapered along the length to get my 11 degree funnel ended up pretty close. I made a simple jig with a couple hold downs on it, this allowed me to secure the thin strips and keep my fingers at a safe distance from the blade. The strips are 10mm thick.
It has some support rings inside that are cut to fit the angle and tapered as best I can to give some support. Hopefully they will hold up ok. Given that is sat for almost 12 months assembled and no gapes appeared in my joins I think it will be just fine.
JPG wrote:Ever made wooden barrels? :D
I think that cyclone is more difficult!
That took a lot of patience.
Kudos!!!
Nope never made wooden barrels, hadn't thought of how similar this is....gives me some ideas :D
Cheers
Marty
Marty
10E S/N 1839 acquired September 2014 restored October 2014
10E S/n 1200 acquired October 2014 waiting for restoration still in use
10E S/N 136 acquired April 2015 waiting for restoration
4E Jointer S/N 862 stripped down waiting for restoration
Mark V S/N 100279
Remarkable, Remarkable! Outstanding craftsmanship! and many more congratulatory adjectives.
AND IT WORKS!
You deserve a big;
ATTA BOY MARTY!!
masonsailor2
Post by masonsailor2 »
That is simply amazing Marty. Wow. I am an ardent believer in build your own tools but yours takes it to an amazing level.
Paul
