lube points on a SS
ERLover
Re: lube points on a SS
OK did I miss one,lubed up the Grayling today, the hole where the spring sits on the motor shaft, and hole up inside the Head Stock by the speed control shaft. I thought there was one more? Could not find anything in the stickies.
Those be the 'prime' ones and the ones most often ignored.
Anything else that pivots could use a mini drop.
Ditto any threads.
Ditto any threads.
ERLover
Thanks JPG, for some reason I thought there was on the lower sheave shaft,since they slide laterally on it.
Motor shaft(under the spring). You got that one.ERLover wrote:Thanks JPG, for some reason I thought there was on the lower sheave shaft,since they slide laterally on it.
