older SS blades worth sharpening?
Re: older SS blades worth sharpening?
ERLover wrote: Why sharpen? you can get blades from Harbor Freight for less then sharpening, and better steel/carbide then the SS steel blades then you have.
Are you serious? Did you do a lab test of the carbide?
ERLover
Post by ERLover »
dlbristol wrote:You are right, I just hate to discard stuff if it is functional.
Save them, but why use a corded rotary phone when you can go wireless? :)
beeg
Post by beeg »
ERLover wrote:Why sharpen? you can get blades from Harbor Freight for less then sharpening.
Why BUY? When ya can sharpen them yourself.
stephen_a._draper
Post by stephen_a._draper »
I have all of the Shopsmith blades. Carbide rip, crosscut, and combination. Steel combination, crosscut, hollow ground planer, and plywood. I use them all at different times. Nothing beats using a sharp steel hollow ground planer blade for miters. Also, nothing beats a sharp steel plywood blade with zero clearance insert for getting splinter free plywood crosscuts. I find all the blades useful and I am glad I have them all. Also, I get just as clean of a cut using a sharp Shopsmith steel crosscut blade as I do using the Shopsmith carbide crosscut blade. Steel blades sharpened properly actually are sharper than carbide blades. However, carbide blades hold their sharpness longer than steel ones.
