Shaper and molder help
Re: Shaper and molder help
It's used for drilling/boring holes in your workpiece. The workpiece spins, and you advance it into the drill bit, placing the hole perfectly on-center. For example, you might hollow out a peppermill body using a forstner bit, or maybe drill a mounting hole in a tool handle.
robinson46176
Post by robinson46176 »
Beave2012 wrote: Well it is tapered, maybe that's why it came with. Maybe one of you turners could inform me as to what use a drill chuck would be in the tails stock? Turning small dowels?
Would you believe drilling? :)
It's a common turning operation in both wood and metal turning. Just a matter of the drill bit standing still and the work spinning. :cool:
Drilling holes in 'stuff' mounted on a face plate.
That is why there is a tailstock chuck arbor. ;)
beeg
Post by beeg »
JPG wrote:Drilling holes in 'stuff' mounted on a face plate.Also in a chuck.
