woodmeister wrote:Part no longer available. I am thinking about heating it with a torch and slowly pressing it closed with and arbor press.
Thanks for the input.
Tom
Part IS available!!!
But only with two other parts as an assembly.
jointer part.jpg (40.49 KiB) Viewed 1563 times
BTW It is supposed to rise slightly above the base slightly when tightened.
Well I put the bar stock into the channel and closed it up inside the vice. It worked great!! Just hope the next guy don't overdo it or it may go out of bounds again or crack.
Did not heat it just slow and steady.
Thanks again everyone.
Tom
SS 500(09/1980), DC3300, jointer, bandsaw, belt sander, Strip Sander, drum sanders,molder, dado, biscuit joiner, universal lathe tool rest, Oneway talon chuck, router bits & chucks and a De Walt 735 planer,a #5,#6, block planes. ALL in a 100 square foot shop. .
