Do you have a volt-ohm-meter?woodmeister wrote:Yes it is the same motor and controller used in my shop smith stand alone planer. Two long screws hold the casing together and are put into the end with plug wire.
planer feed motor problems
Re: planer feed motor problems
- delete post a.jpg (321.56 KiB) Viewed 1212 times
- delete post b.jpg (281.13 KiB) Viewed 1212 times
- delete post c.jpg (253.25 KiB) Viewed 1212 times
