Here is the do-hicky (aka Adjustable Fitting) to which you refer.bmsma wrote:JPG wrote:OH! The Do-hicky that mounts on the end of the telescoping tube.
That do-hicky is a 3/4" pipe railing fitting.
When you refer to a lathe chuck, are you meaning a spur drive, or something fancier(not standard equipment)
book calls it the drive center, the tailstock has the cup center in it, and ill probably invest in the lathe stuff pretty quick,
and i figured ebay, cl and shopsmith have everything ill acquire slowly, just figured id check here first, simple assuming that the folks here have a great chance of taking better care of their stuff.
http://www.shopsmith.com/ownersite/item ... tem=514520
The above is typically used with this Telescopic Leg.
http://www.shopsmith.com/ownersite/item ... tem=514529
I believe you want one of these since you reference the tail stock.
http://www.shopsmith.com/ownersite/item ... tem=505602
And one of these.
http://www.shopsmith.com/ownersite/item ... tem=505715
You have not mentioned it but if you do not have a chuck, here is the one I would recommend.
http://www.shopsmith.com/ownersite/catalog/dr_chuck.htm
That's a couple hundred right quick and then there is shipping.
