What is the 'horsepower' rating?
The HP rating of the switch?
Power Switch stuck powered on
Re: Power Switch stuck powered on
The HP rating of the switch???
The switch is rated at 20amps. That's all I can say for sure.
If it does not say on the switch, I predict a short life.Adagosto wrote:The HP rating of the switch???
What is the Ace part #?
Rocker Switch with lock-out #61314
Jandorf Single Pole, Single Throw On/Off
I appreciate your follow-up and concern.
Thank you
Thank you
IF it also says "1-1/2 HP, 125V AC you are ok.Adagosto wrote:Rocker Switch with lock-out #61314
Thank you
61314 is not a current Ace part #.
Hi.
I see that too.
I googled the name and found several that look identical. None indicate the HP rating. Here is one example.
http://www.essentialhardware.com/jandor ... AtlA8P8HAQ
I see that too.
